frozen boost slim fans
natertater
320
Jun 26, 2008
san diego, California
so i was checking out their parts and kits, and wondered if these would be good enough for fans on radiator. they only draw 4a and flow 1250cfm. not too bad for 10" fans, and only 25 bucks a piece.
Electric Radiator Fan
anyone else use these for other than heat exchanger on w/a ic kits?
both. i know they would need plugs spliced in to work with stock harnesses...but yes both
Is this because of a FMIC that you are adding and you are keeping the A/C? If so, then I wouldn't do it. At the very least keep your Main fan (the one on the passenger side) and only replace the A/C fan with a slightly smaller one. With a 12inch instead.
no, was thinking of getting slim high flow fans for the cheap. i guess these arent good enough. i really want to do an w/a ic vice front mount...but not sure which one will fit in stock smic location without too much hacking. will have to get ahold of frozen boost to check on that later.
