Front turn signal lights
You can open the headlights two ways..Putting them in the ovev wich I don't reccomend..Or steal your gf's or moms hair dryer, heat up where the two halves of the lights come together and pull them apart .. It might not seal correctly after putting them together, so adding a little sealant or caulk is not a bad idea..Otherwise you will get water and crap in there, and it will burn your bulbs up real quick..
Or like stated before ebay headlights are the easiest route..
