Turn signal problem
NewClipse96
89
Apr 26, 2011
kissimmee, Florida
Ok so I replaced my bulbs in the turn signals cause one was out. Well after I did when I turned them on they worked an all thats not the problem but in my dash the little turn signal light that flashes when there on (idk what its called) just stays on when my lights are on only the left one does anyone knows what the problem might be or even no what im talking about atleast LOL?!
It's more than likely faulty wiring. When I bought mine, all turn lights worked and blinked fine. I've since replaced all lights with LEDs, and they all did the quicker blink speed, but blinked. Now my left side blinkers stay lit without blinking, just like yours. My guess is that I could have crossed a couple wired or something similar, or the relay is going out. I just no longer use the left ones until I fix the issue.
Well that would be how you pull the bulb out of the cluster, but has nothing to do with the wiring of the lights themselves. The cluster bulb only mimics what the turn lights are actually doing.
  • Wanted 6 bolt NT water pipe
    • chrisman287
