Front LSD Insert
TheBoz
268
3
Aug 6, 2004
Riverside, California
I have my trans appart for the Welded Center diff, and while it is appart I am thinking about doing the FRONT LSD Insert. Can I get some opinions on them. I need the good the bad and the dirty. Remember this is for a 6-700hp car. So High HP guys please let me know what you think.
Also I have searched and it seems that these are a bad idea from everything I have read. Looking for some good up to date info on these products.
I did quite a bit of research on this myself before deciding to do it or not. The conclusion that I came to is that if your running a car with over 4-500 hp it's probably not a good choice. There are a couple of threads on here in regards the the inserts that you might find useful.
All in all if it were my car and I planned on putting that much power down I would go with a true LSD system. It'll cost you quite a bit more to begin with but net you better results and stop you from possibly having to buy a new transmission.
