front lower control arm bushings
kidtsi
1,417
17
Feb 17, 2009
Laredo, Texas
I would like to replace just the boots or bushing, whatever you call them because i bought some dorman lower control arms and the bushings are split in half in less than 6 months and making a clicking noise. i have warranty for both sides but i would like to remove the weak bushings and put oem bushings on them.
somebody knows where to get stronger or oem bushings that covers the grease in the ball joint? the bushings that comes with the autozone control arm are cracked already, i really need help.:pray:
There is only one type that can compair to OEM and its poly. but i havent found any poly's for the 2g's yet. get some oem and you will be covered for a long time without problems. here is the link.
JNZ Tuning Online- OEM Mitsubishi Parts
