Front end makes music
972ndgen
Apr 24, 2006
Cortland, Ohio
I got a problem, I have a 97 gs and the front end make more noises than Beethoven. It all start with the wheel bearing it started to rumble, it has a crack in it.. after awhile it started to sound like my ball joints were shot. So i guess my question is when i turn my wheel left or right my front end squeaks and my power steering hardly work. could it be the ball joints, power steering pump, or what. thanks
While standing in front of car, looking into engine bay, the power steering pump is the first accessory you see. Left side of bay, in front of motor. The belt tension is also adjusted there. Adjust the tension so there is 1/4" to 1/2" of deflection over 12" belt span.
