front crossmember bushings??
sandiballs287
79
Oct 2, 2008
Jax, Florida
i've been doing some research and i can't seem to find bushings for the front crossmember or you may call it engine cradle, so i can replace the worn ones. i need to get them asap. can anyone point me in the right direction. oh yeah its for my 98 gsx :confused:
If you are not talking about the ones in the link. No one makes them for the bar that runs north and south that bolts to the radiator core support with the front roll stop mounted to it. Might try the dealer to see if you can get new OEM ones.
Kevin
Why not?
"Nobody" makes "cross member" bushings but today I was working on my 92 GSX and as I was installing my subframe bushings I decided to pop out one of the crossmember bushings and it was the exact same as the smaller bushings in the subframe. So my options are to order another subframe bushing set or call energy Suspension and ask if I can buy the inserts and sleeve separate
This is a 1g part so not sure on the 2g front crossmember
The whole kit was only 40 bucks so not a big deal
It's a 2 part bushing with a a sleeve and two washers
PT# 1008 main bushing
1019 second part of bushing
15.10.177.39 sleeve
15.03.05.39 washers
The 3G crossmember bushings are the same as the 2G, and Energy Suspension sells them with their 3G Manual Motor Mount kits. The bushings part number is 2476
