Rear crossmember/subframe and trailing arm bushings?
etay89
866
6
Dec 27, 2009
Monroeville, Pennsylvania
So I'm in the middle of doing an AWD swap from a rusty GSX to a rust-free GST and I finally got the rear crossmember out. Problem is that some bushings are SHOT, which are the trailing arms and the 4 bushings on top of the crossmember.
I want to order these but I've searched through some kits and haven't found them. I saw a user on here that sold metal bushings but I'm not interested in the sound that follows.
Any rate, anyone know where I can get JUST these bushings? If I have to buy a set, that's fine, as long as I get these bushings. Thanks.
The trick is to search for "2G DSM bushing master set"; I believe they only included the rear subframe bushings in that set and didn't sell them separately.
I do thank you for your response..but it say that, "Before you reply, 3.Don't try to help if you don't know the answer - bad advice is often worse than no advice (no "I think" or "I guess" or "I've heard"). If you see misinformation being posted, debate it respectfully.
Atleast you gave me a lead though. I knew about the master set, but I can't find product details ANYWHERE
Adam Porto ( black_gst ) makes a set of poly bushing for the 4 bushings on top of the rear cross member. If you are talking about just the isolating pads (thick rubber coated washers) on the top. I'm not sure if he reuses the OEM ones or supplies new ones in his kit. I am 99% sure that he is the only one that offers these bushings. His bushings are top notch and he is great to work with. Shot him a pm.
For the trailing arm Prothane makes a nice set that comes in their master kit. If you call them directly they may just sell you what you need. They have done this for me a few times.
Here is a link to what the Prothane master kit replaces.
http://www.roadraceengineering.com/parts/prothane/
Kevin
