Front Control Arm bracket
25gtalon
Jan 17, 2012
Waxhaw, North Carolina
Hello all I am in the process in replacing all my suspension bushing in a 1990 Talon TSI AWD however I run into a problem, the clamp bracket for the 1990 AWD is no longer available from the dealer and none available in the US. Here are the part numbers
MB518343 Front AWD LH
MB518344 Front AWD RH
Can some one lead me in the direction of where can I purchase new ones, or an alternate solution to replace the worn rubber bushing. Thanks fro your help.
Polyurethane ones no?
Just get the metal bracket and you are good!
Those are control arm bushings, he needs the brackets that secure the rear bigger bushing to the subframe. OP, I tried and source them from JNZ a few weeks ago but the ones for AWDs are no longer available . I don't know of just the bushings being available as aftermarket either.
The polly bushing I have it the bracket that secure the rear bushing to the sub frame for the AWD is what I need. Thanks
