Front Control Arm and ball joint AWD
flaatr
265
Oct 18, 2010
San Jose, California
I think one of my ball joints is bad... I get a clunk from the front during had cornering...
I was told that replacing the ball joint correctly is a pain and that I am better off buying a replacement control arm with a new ball joint installed than to replace the part on my arm... This advice cam from a guy who works at a shop that does DSM and EVO work exclusively.
Does this seem reasonable?
-Raffi
It's real easy to check them. Jack the car up, remove the wheel than pry the control arm down and see is there is any play in the joint. It is real easy to change the ball joint if you have a press, or if you rent the ball joint tool from the parts store. You can get the ball joints from rockauto.com for like 20 bucks or less. You don't even have to remove the control arm from the car if you rent the tool. Just pop the ball joint loose from the knuckle, swing the control arm down and you will have enough room to do it there.
Replacing the ball joint makes sense if the rest of the lower control arm is in good shape.
The rubber bushings go bad over time but there are poly replacements available.
The arm that goes into the rear mount can corrode and then the LCA is trashed. It's real common in the rust belt but in San Jose you may not see it.
Good info... I'm assuming the ball joint is bad, I haven't checked it. In a hard corner I get a loud clunk from the left front...
I'm doing coilovers/swaybars/poly bushings soon so my plan was to replace the ball joints anyway. I'll spend a few minutes with the manual and look into getting a tool... doesn't sound too hard.
-Raffi
