Front Balance Shaft Removal
r3dmak
85
139
Nov 4, 2007
orlando, Florida
Hello all, so I found myself in the pickle recently and in need of some help. So my plan was to delete front BS and replace back one with a stubby shaft, however, I forgot to turn front bearings to block the oil ports. With that being said what are my options now given that my block is already assembled and the head is torqued down? Is it still possible to turn the bearings? Pic for refernce
If your picture shows its current state, pop the bearings out and reinstall them clocked accordingly to block the passages.
Yea, when I did mine I didn't need to access anything through the top. You should be able to see everything through the bottom or even through the hole circled.
Take a long extension, put a socket on it and bang out the old bearing. Then flip the socket around so then you can slide the bearing on the socket end and use that to feed the bearing back through the hole. Give it a few taps to get it started and then flip the socket back around and finish off getting it seated in place.
I've also heard the there is a freeze plug or something that can be used to access the oil port but that's something I'm not completely sure of.
Also, make sure you get the better quality delete kit which had the oil passages in the nub too keep from causing friction and scoring anything up.
Oh ok, thanks for clarifying that, I was afraid its going to be leaking outside and drip on the ground. Would Kiggly HLA help stabilize the oil pressure?
The only true concern when doing these, and the reason for flipping the bearing is mostly to ensure that oil pressure stays at a good level. The concern is never really with oil leaking.
