justinh722
- 131
- 1
- May 3, 2010
Hampton,
Iowa
I have a 2g gsx chasis that I'm looking to drop my 6 bolt engine in. It was pulled out of my old 95 GST in running condition. I was running E85 and a small 16g turbo at about 22lbs of boost. When hitting around 22 lbs, the coolant would get pressurized and leak out of the overflow. I know it's my head gasket.
I have 300 bucks (for now) to spend on some maintenance items. I'm thinking of going the composite fel-pro route and some ARP head studs. Engine has 120k on it. Recently had a new timing belt and tensioner put on. Engine still has the balance shafts. Also has a 1990 throttle body on it. I went the cheap route with the intake gasket last time also. If you had 300 dollars, what route would you go? Thanks
