ziggo0
- 774
- 9
- Oct 13, 2009
La Porte,
Indiana
I did a rebuild of a 6 bolt I bought off a friend. It was bored 0.030 by a reputable machinist. He also did the 1g rods to accept 2g pistons and mounted them too. I put the build together over a few days, bottom end went together very nicely! New Clevite bearings, standard size as crank was in std condition. All bearing clearances were within tolerance. Piston ring gaps were 0.019 & 0.024, everything torqued to spec from the oil pan bolts to the cam cap bolts. Assembly lube on all rotating surfaces (not back sides of bearings). Primed oil pump with an impact gun, ran it long enough to see oil in the head/turbo feed (oil pump is new also). Running conventional 10w30 oil, 4.6 quarts of it.
Started it up last night and it fired after the 2 time turning over and went straight to 750rpm and idled for about 5 minutes around 900, no surging or anything. Went to go do the break in for the rings (4/5.5k rpm, 2nd and 3rd gear decelerations for about 10 to 20 miles). At about 8 or 9 miles I started to get rod knock, not lifter tick. Get it back to the garage, drop pan, lots of metal shavings, rod 3 had spun. There was about half of the bearing left for each one, crank looks a bit torn up but nothing a polishing couldn't fix - this is not what concerned me however.
When I took the rod cap off and went to push the piston/rod up...the rod did not want to freely move on the wrist pin. Before the build and install it moved just fine, was lubed up plenty and oil squirters are installed. It can be moved if I force it to, it doesn't take he man strength to move it but it takes take a little convincing - does anyone have an explanation onto how this bearing spun and the rod is seizing up on the wrist pin? I'm going to call the machinist tomorrow and get his opinion but I'm in a bit of a panic now because I no longer have a ride!
Didn't realize I put this in the Newbie section, my mind is very scattered with this sheer stupidy of this happening.
