FPR, Rail, Injector, Pump install q's???
l2yanE
Feb 5, 2006
Front Royal , Virginia
Ok, last night I install my walbrough 255 pump, put in my new 660cc injectors, and my new fuel rail. Now the problem i have was the aeromotive regulator install kit is for the stock rail and im not using it. Is it ok if i use the an nipple fitings and i have some high pressure super high temp race fuel hose to go between the filter, regualtor, and rail??? as in using hose clamps?
<center>
<img src="http://i48.photobucket.com/albums/f230/MRTPerformance/IMG_0318.jpg" alt="Image hosting by Photobucket"><br><br>
<img src="http://i48.photobucket.com/albums/f230/MRTPerformance/IMG_0315.jpg" alt="Image hosting by Photobucket"><br><br>
</center>
That should be fine as long as it is Fuel injection hose. I just did my fuel ssytem and decided to put in stainless lines because then I was able to put in a better flowing fuel filter, and it's impossible to find an adapter for the stock rail that just goes to a hose barb. Depending on your AFPR that you use, if it's 6 AN, you will have to step it down to 4 AN in order to fit on a hose diameter that will clamp to the stock return line.
