Syndicate13
- 1,511
- 31
- Jan 5, 2003
Ft. Myers,
Florida
Ok, on a 95 turbo DSM are the injector leads both supposed to have power all the time? I know on most cars that one side has power and the other in ground and then the ECU pulses the ground to open the injector. Do our cars work the other way wround? I recently installed a DSMchip and now my car won't start, we've pretty much traced it to the injectors not firing. With an OHM meter on either terminal on plug the voltage doesn't pulse at all, it drops to about 10 while the starter is cranking but stays the same instead of pulsing like one would assume it would. Also, can anyone confirm that on a 2G when the key is turned on, the CEL should illuminate for about 5 seconds then go off to indicate that the ECU is booting properly. Thanks for any help.
