FPR Location
1969olds
44
Jan 1, 2012
Rochester, Indiana
Where is the stock fuel pressure regulator located on a 2G? I'm going to be installing an Aeromotive 1000 here pretty soon, as the previous owner put on a Walbro 255 and no regulator. And where is the best/easiest place to mount the new one?
The stock FPR is mounted on the side of the fuel rail. Looking from the front of your car at the motor: right behind your oil cap. The aftremarket will connect there but you prob wanna get the install kit with lines and fittings. Some mount on the fire wall.
They have a regulator that bolts right to the rail. I think its sxracing. I have the aeromotive one and its great. Just make sure it has a gauge. I mounted mine right behind the rail on the firewall.
