FP3065 to FP3582HTA
Mobile_DSM
Dec 17, 2007
Mobile, AL, Alabama
So I'm about to step up to the 3582. I'll be buying a T3 header, but I'll need to find a 3" O2housing. V-band to turbine housing and either v-band or flange to dp. If you know of any, please post a link.
FP has nice 3" o2 housing , plus i think that you can order the HTA3582 CHRA and change it with your FP3065 CHRA then using your fp3065 exhaust housing .
if not , i believe the best t3 header manifold is shearer ( ::ShearerFabrications.com - Home:: ) , another choice is DNP manifold .
good luck.
I ran 11.7 on pump and 23psi with it, but my bottom end needs to be rebuilt. It has 144k on it and I'm getting ready to tear it down. The 3065 is great for what it is, I just wanna make more than mid 500hp. I know you can change parts with the 3065 and HTA3582 but doing this will yeild lower overall power potential. For maximum power output you must keep the setup all Garrett. I think I'm just going to build my own O2 housing and DP all 3". I know FP sells a O2 but they are outrageously overpriced on it.
Thanks for the info. I just received my FP 3065 and will be happy with mid 500hp. With my new direct port I should be able to meet my 10 second goal.:cool:
good luck.
One more that not many know of. The ERL cast stainless T3 manifold fits 2g's and 1g's.
