TurboDSMer
- 174
- 1
- Dec 2, 2003
Burlington,
Massachusetts
Will denso 720cc injectors be fine to use on a red or do i need to go to something bigger?
TurboDSMer said:Also would a Tial 38mm wastegate be fine to use with this turbo as well? I was planning on maybe 20-25psi daily on pump gas with that wastegate.
CanadianTSi said:I know for a Fact that a 38mm off the Number one runner will hold a 60-1 to 6psi with no creep.
92awddsm said:I know for the most part that the 38mm will control boost high or low but there is always that random person who has creep issues with running low boost on a big turbo with a 38mm wg. Thats why I stated that it might creep.
