Fp green questions
blasterracer817
71
3
Jun 29, 2012
Winona, Minnesota
I have a few questions about the new fp green. I've been wanting this or a buschur 20g. I however cannot find info on spooltimes or Max boost etc about the green. I realize every setups different. I'm just trying to find relative info. I want to use this as the secondary Turbo in a compound setup eventually or the buscher 20g. Any info about the green would be great. I'm shooting for about 375-400 HP with it being a fast spooling street car and occasionally used in auto cross. Thanks in advance
Then you want a TD05H 20G, or perhaps even the new FP 71HTA.
Keep in mind a Buschur 20G is just a TD05H 20G with a 25* clip on the turbine wheel. No reason to pay more for a name.
Fp Green, all the way and I even have the old one.. It kicks hard and fast. Best street turbo I think..
Thanks Justin are there any supporting vendors that sell the 20g?
Not really, although you can build one yourself if you have a Big 16G or Evo III 16G that is blown but has no turbine damage and would be worthy of an upgrade.
What would the 71 spool like?
No clue as I don't know a single person who is using one currently. Perhaps FP knows from R&D/testing. Definitely faster than the Green due to a smaller and lighter rotating assembly.
What are your spool times like. When do you reach full boost.
Justin. Thanks for the info. Ill try and get ahold of forced performance and see what they say about the 71hta
Well, I would say 17-18psi by 38xxish.. 25psi by 43xxish.. Have not really checked it in a while to be honest. I can double check tomorrow.
20G is perfect and cheapest route. Unless you ganna push a lot cams race gas e85 or if its your daily driver then go big. Other wise 20g is good and can be found 1/4 the price of a fp green.
