Fp green fuel setups & HP
awdmonster1904
Freelancer
827
475
Aug 23, 2007
Chino, California
I'm currently in the works on installing my FP green along with my jmf race manifold
I would like to know is how much power you u guys had on pump or E85
Boost level ect and what fuel setup worked o. Your car
The reason Im asking is that I'm not sure if 1200cc injectors would be enough for E85.
If I got with pump 91 I know that 1200cc will work but how much power will it make on poor octane
My profile is up to date minus the 20g and jmf smim
My goals are to run low to mid 11's. 450hp on stock bottom end
Thank you
Frank the tank
HTA fp green? if yes i have it.
I have the older style fp green
Do share your fuel setup how much boost and HP i just saw your profile are also running E85 with meth ?
I would like to know as well. I'm deciding on a green/red for my 1g.
Since parting out my 2g, I've got quite a bit of fuel to use in my 1g. PTE 1600cc injectors, Magnus rail, Aero AFPR, and bought a DW300 for my e85 needs.
I am in the low 500's and I use two walbro pumps and 1680 injs with two -6an lines out of the tank into a -8an line all the way up on stock return lines. I am using E85 also. I was running 1350cc before and I was maxing those out at 27psi. E85 requires alot of fuel.
I would suggest to over build your fuel setup. Can't hurt
I ran the older style FP Green at 30psi with E85 on 1 walbro 255 and my duty cycle was 90% on the FIC blue max 1250's and stock FPR. Tuned with AEM EMS. FP green is a hell of a good turbo with the right set up and tune.
wondering how much whp did you hit for 30 psi on 1250's? so i'm guessing with 1000's with less psi should be alright.
Im running 22.5 psi on pump with FIC 850cc injectors and making 412awhp and 434.5 torque. This was running way lean too cause of a miscalibrated wideband so i had to retard timing to suppress knock. I was wondering why it was so knock happy at 11.1:1! Now it really is 11.1 and the timing is back up substantially as well as 24psi. As soon as i get the new clutch in im guessing around 430-435awhp
