Fp Black + stock coolant lines
9412tsi
53
Dec 1, 2014
pittsburgh, Pennsylvania
Searching has brought up mixed results.my water lines are bent to shit from moving the engine around, so I was gonna get these oem replacements from stm:
Will I have any trouble installing them on an fp black turbo?A little bending I will be ok with I just want to know if they will actualy work.
When i installed my fp red the lower line didnt reach, it was really close. The line hits the compressor cover. I ended up cutting the line and connecting both ends with a hose
yeah I was thinking worst case cut it in half and splice a piece of hose on it.do you happen to have any pics of the lines?
Those look like 2g lines. You need fittings that mount to an mhi style chra, not the Garrett chra from the 2g t25. I would just get barbed banjo fittings, and run new rubber lines.
One of them has the threaded connector at the end that attaches to the water pipe, definitely 1G. I've always used stock lines with downfiring MHI frame turbos, works fine. Might have to bend the rear line to clear the comp. cover a bit. I'm using stock lines on my HTA76 bolt-on, still works with a bit of tweaking. I'm not a big fan of aftermarket coolant lines, the AN fittings are always more of a pain to work with in such a tight space.
thanks guys, and the barbed fittings are also a good Idea to!
