FP Actuator
EclipseGST-95
531
Aug 5, 2003
Newark, Delaware
Not worth it, especially if you're still on the t25. All these do is change your minimum boost from the 11 psi that the factory wastegate is rated at to 17psi. (IOW, you won't be able to run anything less than 17psi) This is meant for larger turbos that are more efficent at this boost range. If you want to run 17psi, save $60 and buy a manual boost controller.
