Fp 30 T31 style turbine housing t3/t4 stage 3
nkosi
320
3
May 17, 2004
montreal, QC, Canada
hey can any one tell me if the turbine wheel on a bullseye T04e 50-Trim is a stage 3 turbine wheel ...i bought the turbo from extreme psi late last summer and now i want to change the turbine housing for better flow and external wastegate to a Forced performance Fp 30 t31 style turbine housing ... i called bullseye to see if the turbo i have from them is a stage 3 turbine wheel and no luck which i dont understand if they made the turbo ...anyways if some one could help me determine it the FP 30 T31 t3/t4 housing will fit my bullseye T04E 50 Trim ...heres the links to both turbos...:D
Forced Performance Turbochargers: FP30 Style T31 Turbine Housing
Import Performance Parts - Bullseye DSM Turbos
There's a good chance your 50-trim has the T31, but Bullseye likes to use P-Trim turbines on turbos with undersized compressors for no reason (T04B V-Trim), so it's best to measure.
hey man thanks for the response ...can u go into more details on how to measure the turbine wheel and housing on the bullseye turbo ...heres the link to the Fp 30 style t31 housing and want to use and they have a 60-trim called Fp3160 which i guess is a t3/t4 ...take a look and let me know.... :D :thumb:
Forced Performance Turbochargers: DSM FP3160 Turbocharger
nice dude i have a good dail caliper ...i will measure the turbine wheel and post the numbers here....thanks again sir
