jcorkin
- 1
- Feb 9, 2015
Hubbard,
Nebraska
Finally got to work on the non running 93 tsi awd that i bought a week ago. Guy just put a new head on it and couldnt get it to run so first thing i checked was the timing and this is what i found when i put cylinder 1 at tdc.
So I reset the timing and crossed my fingers. Well she started but wouldnt idle on her own and no power but would rev when it finally got above 2500rpms. So i shut her down and checked compresion and found 0psi on cylinders 1 and 2 and 160psi on 3 and 4 so guessing a couple valves got bent when he set the timing wrong. So now im going to build the head a bit, thinking delta hks 272 regrinds and arp studs, what do you guys recommend for valves? My max hp goals for this motor are 500hp.
