blazer316
- 0
- Sep 13, 2009
Winston-Salem,
North Carolina
I found a 1990 eagle talon awd 5speed for sale for a pretty good price but, it says it has an idle proble. I asked the guy about it and he said he checked alot of stuff like boost leaks,ecu,idle ajustment etc. after it gets to operating temp idle jumps and fluctuates from below set idle to up to about 2k sometimes. He did say he removed one of the honeycombs though so I wonder about that? Otherwise the transfer case whines a little so i could probably get a used one for 350-400 if need be right? and it needs outer passenger door handle fixed. but anyways he said the 14 b turbo went so he through a evo16g on and 3 inch exhaust but the rest is stock. He does say he just drives it easy, still stock everything else and evo 16g? It will need bigger injectors for sho. What do you guys think about the idle problem and does the honeycomb and turbo relate?
. If you need to know anything else then feel free to ask since I drove the car and saw it in person.
