Forward facing OEM water pump options
turbosax2
Moderator
4,482
669
Nov 19, 2006
Mechanicsburg, Pennsylvania
First off, yes, I'm aware of the Jay Racing water pump adapter kit:
http://www.jayracing.com/dsm-coolin...an-fitting-adapter-kit-front-inlet-p-216.html
I'm trying to locate an OEM water pump (no matter what make car it was originally on) that has a 2g water pump bolt pattern but with the inlet facing to the front of the car. This exists for a 1g bolt pattern (MD997615 from a Mighty Max), but I haven't been able to locate a 2g one yet.
I've cross-referenced the 2g gasket through ASA North America, Europe, Japan, and General Export and found the following chassis codes use the same gasket, but all the pictures have the inlet on the side like our factory pumps do.
I also cross-referenced the gasket at Rock Auto, but all of these pumps face the same way as well.
Any suggestions?
I use that style pump on my 2g 7 bolt. A 1995ish mitsubish express van/l300, I think it was a 2L 8v sohc. It did need a few bits trimmed but bolts up fine.
Seems like the most logical thing would be to put a freeze plug in the water tube side, and weld your barb or a/n fitting to the spot that originally had the freeze plug.
Something along those lines is my backup plan if I can't find the pump I want.
Thanks for the input! I don't supposed you happen to have the part number for the pump you used, do you?
Um, you do realize that the OUTLET for the OEM waterpumps is through the block, right?
Um, I had a little typo in my post. Sue me :p
If you're going along these routes, why not fab some tubing up, elongate the arm where the freeze plug is, and weld the OEM port shut
I don't know of any of the big names running anything but one off fabbed up waterpumps.
Why would I do that if that exact part already exists without doing any work?
Who cares if any of the big names are running fabbed water pumps? WTF
It may or may not exist. But caged says it does exist, so I'm going to pursue this more.
Please forgive me for trying to do what I want to do.
That being said, if you have nothing else insightful to add to the thread, please don't clutter it any more than you already have.
I just found that picture, and it makes it look like the inlet of the pump is angled up much more than a DSM one does. As it is with the DSM pump now, I won't even be able to put the hose all the way to the edge of the water pump because it will hit the bottom of the power steering pump bracket first, so having the inlet angled up like that would put it right into the power steering pump for sure.
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
