Forgot to label the lines
RichardsGST
46
Jul 7, 2004
Des Moines, Iowa
This is the problem, i forgot to label where my hook ups went. Like the oil lines and antifreeze lines. If you can help me out that would be great. If you know a site or something with a picture. Or if someone can take a picture for me of there engine and where the hoses hook up that would be great. thanks
What turbo are you hooking up? For the Mitsu style turbos, the oil lines should go on the top and bottom of the turbo and the water lines are on the side.
If you're asking what actual lines go to and from the turbo, then the oil line (if it's still stock) is the hard one from the oil filter housing and goes to the top of the turbo and the hard return line goes from the bottom of the turbo to the oil pan.
The coolant lines are side to side, can't remember which is in and which is out, but if you left the stock rubber lines in place it should just line right up.
For the turbo i am running a big 16g. i know where the oil feed line hooks up from the head. the thing i dotn know is there is a line coming out of the block. i dotn remember where that goes to. there are two lines on the oil pump housing and one looks like it goes up to the water piping. if you had a camera with pcitures that would help. that would be great. if not hta tis cool.
I'll see what I can do tonight with pictures when I get back home.
While you're waiting, check out the VFAQ www.vfaq.com and look under Turbo in the top menus and then go to 16G install for 2G, it's the 3rd and 4th ones down. See if that helps you any.
Also, where does the oil feed line come from in your car. I thought the 2G's came from the oil filter housing and the 1G's came from the head. And where is this line coming from the block? Is it a hard metal line or a rubber line?
If you can get pictures of each line I could tell you exactly where they go.
i got a 1 gen engine in my 2g. under neath the water piping there is a place to put a hose. It comes straight off the block. on my oil filter housing there is two lines too. give me an e-mail address i will see what i can do.
ok.. one oil line goes to the oilpan thats the one on the bottom of the turbo.
then there is a coolant line that goes to the tstat housing... then the other coolant line that goes into the water pipe...
Thanks that will help. but something is supposed to go right under the water piping onthe block. do you know what that is.
I didn't get the pics tonight, ended up being too dark by the time I got home. I cannot picture where this line is coming out of the block. If you can take a picture of it, that would help immensely.
