DSMunknown
- 4,108
- 43
- Sep 16, 2004
Worcester,
Massachusetts
I believe I have a boost leak and am not sure where it is coming from. Also, my Forge 1G re-circulation valve (RV) is not performing properly.
A few things you need to know:
There are a few points regarding the Forge RV and performance when I have done some WOT pulls:
Update:
Now, I would be inclined to assume that the CEL came on because one of my sensors has failed and needs replacing (particularly, my PCV probe sensor). I am assuming this because I followed the guide and the guide tells us that the PCV sensor needs to be disconnected, so perhaps I damaged it somehow (although, I see this as doubtful because I was very careful not to scrap it against anything).
I am also assuming that my problem is directly related to my replacement of the insulators, because the CEL was not on before I performed the install, and the performance of the engine wasn't nearly as bad as it currently is today. Therefore, something must of went wrong as an indirect/direct result of the install process. The only other thing I can think of is that my valve cover gasket is leaking from the intake manifold side. I will go out and put soapy water all over that area to make sure it is not that.
I did more boost leak tests today (Thursday). The leak almost sounds like it is coming from inside the intake manifold (because it is a little bit muffled). However, I am just guessing; I could be way off.
- My vehicle profile is fully updated.
- My car is a daily driver, during the summer, I run 15-16psi. However, now that it is the winter season, I have turned down my MBC to about 12-13psi.
- Regarding vacuum, I generally see between 15 and 16 on a consistant basis, although I will hit 17 every now and again. I was told by Andy M. that I should be consistantly in the 17-18 in.mg. range, but this is the least of my problems right now.
- I have done boost leak tests in the past and am very familiar with how to properly perform them.
- I performed this test about 10-12 times in the span of an hour, so it was not just one single pressure test that was performed.
- The reading on the gauge never stayed constant for any length of time. It simply was a gradual decline from whatever psi I chose to peak at.
- I replaced all of my fuel injector insulators (aka o-rings) this past Monday because I had a leak at #4. I used this article as a guide, and I also used RedTurboEclipses cheap fix to replace all four old OEM insulators, even though only one of them was leaking. I followed the first article to the letter, and I did not unhook/unbolt/disassemble anything that was not in that write-up except for the battery. I had to take the battery out because one of the metal connections keeps coming off of an ignition wire. Here is a photo of what I am talking about (the metal connector is inidicated by the red circle). By the way, the wires that are pictured are not the ones I am using, I simply took this off of Extreme PSI's site for a quick reference:
- I used lots of soapy water (all over the injectors, the top of the intake manifold gasket, the BOV vacuum hose, the BOV, the top of the gasket between the TB and intake manifold, the top of the gasket between the TB and the TB elbow, the PCV valve, the end of the PCV connection, the FPR, and other places). Here are some photos to help out those who reply to this thread (the red circles indicate where I put the bubbles):
- When I cleaned out the TB area with Deep Creep, I reinstalled the OEM gaskets with regular black RTV silicone, so as to limit the possibility of leaks. I am confident that there are no leaks coming from that area.
- I tested the system consecutively up to 20psi, and one time at 25psi.
- I used this device to give me immediate readings on the level and reaction to the air that was injected into the system:
- Obviously, there is air coming out of the valve cover (where the oil filter is naturally connected to). Thus, I am struggling to hear over the escaping air. However, I put my ear so that it was practically in contact with the middle of the fuel rail. The air leak seems to be coming from around the intake manifold area.
- The CEL light came on today, but on Monday when I took the car out (naturally) it did not come on.
- I always quadruple-check all of my lines/hoses/connections - I am very persistent on myself regarding this, so I am more than 95 percent sure there are no loose/forgotten connections that I simply have overlooked.
- For anyone who is familiar with this RV, it is supposed to hold boost extremely well.
- I am currently running the green spring, supposedly good for 5-15psi, but is known to hold even more.
- I recently received my RV back from Patrick Robles over at Forge Motorsport for the revised lock ring after sending it to him to fix it (the old one was leaking like crazy).
- Forge also proves two plates to aide the springs with keeping the RV closed and hold boost. As you can see, they are not currently installed (I just dont see them as necessary for the amount of boost I consistently run).
- Over the past two days (that is, Monday and Tuesday) I have done about ten WOT pulls, with generally the same results.
- The RV does not seem to close like it should. When I am traveling with between 10 and 0 amount of vacuum, the RV is partially open and re-circulating back into the intake pipe. This is normal and this is what it should be doing. I can hear when the RV is doing this, because there is a constant hiss. However, the problem is that in second and third gear the RV does not want to stay closed when I put the engine under heavy load. Over the past two days, on some WOT pulls, I have seen the gauge read as high as 7psi (!!!) and the RV still be partially open.
- Additionally, the RV seems to perform normally and hold boost in the higher gears (that is, fourth and fifth), regardless of RPM or throttle position.
- Last night I made two consecutive passes in second and third gear. The first time the gauge read 7psi with the RV still partially open (I know this because I can hear the distinct hissing, similar to the hissing when I am traveling between 10 and 0 amount of vacuum) when under WOT. I kept my eyes on the boost gauge, and the RV did not close until very high in the RPM range. I decided to do a second pull and try and remember to look at the tachometer right before I let off the throttle. This time, right as the boost held and shot up to 10+psi, the engine hit 5500 rpms and was climbing. The throttle was roughly about 90-95 percent open.
Update:
) you some home-made peanut butter cups for your long trip home. What will you be taking, the Mass Pike-to-395? I will call you and PM you the directions.
, along with a couple VCs soon. Honestly I would spend the $10, and have a machine shop make you an EGR block-off or get one from SBR, or w/e to see if it fixes it. But then again Mass, is one Nazi state on mods
