Follow up to my horror story of obtaining my GSX
98spydert
1,916
8
Jan 16, 2004
Phoenix, Arizona
:::EDIT::: Apparently my story violates Blog rules by including accusations and personal complaints and I've been asked to remove them. I left the story the same and just deleted the personal info to comply. The point of this blog was really more to tell the horror story of how I got this car rather than bash the piece of shit who dicked me over. :::EDIT:::
If you read my first blog, you read how badly **** ****** screwed me over for approximately a year and a half. Here's the follow up drama from retrieving my car from him:
After getting my car home, I start re-torqing bolts and double checking everything. Here's what I found:
My new OEM oil pump and JNZ tuning BSEK were replaced with a Topline pump and the rear shaft was just hacked off with an angle grinder. He had told me some story about getting the wrong pump in the mail and having to pay $270 for a Topline locally and how my JNZ kit wasn't the right kit for the 4G64 (complete bull shit, he installed them on his own 2.3 build and screwed me over) and I this before I left, but what I didn't know is that very unbalanced shaft ate into the pump and ruined it. Luckly it did not suffer a catastrophic failure.
My OEM overhaul kit was not used! Everything was old, reused aftermarket junk. The timing belt was a stretched out Goodyear belt instead of the 4G64 OEM belt I supplied. And the OEM 4G63 belt that was in the kit was kept for his project I guess.
My fresh head had 8 different valve cover bolts holding down the valve cover and most were the wrong threads, forced into the head.
The power steering pump was held on by one bolt. It had moved during the trip and the pulley had ground off the head of another bolt. Somehow it didn't suffer a catastrophic failure.
The t-25 was hanging on by a couple bolts, the water lines were plugged and not used, and it was spewing oil into the exhaust.
The transfer case was missing bolts but again, somehow didn't suffer a catastrophic failure.
The 4 oil drain holes on the back of the 4G64 block that need to by plugged because they don't line up with the 4G63 head were not plugged. They had pieces of a Mountain Dew can laid over them with RTV holding them down. Oil sprayed out of them and all over the engine bay and bottom of the car for the entire trip so I just kept adding a little oil every few hours. The undercarriage was soaked all the way back to the muffler
The MDP sensor, throttle body, timing covers, and other various parts were all broken and patched with RTV and JB Weld. This install was the definition of a shade tree DSMer.
There were other little hack job tricks here and there and I'm sure more major issues I'm missing. You get the picture...
After all of this I tell **** that I want my OEM overhaul kit and 4G64 belt along with everything else he still had of mine. He says he'd send it to me the following day, AND I NEVER HEARD FROM HIM AGAIN! Big surprise...
My future blogs will be focused on my un-build and rebuild of this car. I've got a lot done in the last 4 months and have a lot more to do. I'm picking up my OEM oil pump, BSEK, timing gear, and brakes on thrusday. Maybe I'll make a more positive entry next weekend and have my car back on the road! Time will tell...
No problem - could I get you to edit the title so that people don't think the blog is mainly about a classifieds complaint... maybe something that reflects your car build. I just don't want people thinking this blog entry violates the policies, as we'll keep getting reports about it.
Sounds like a raw deal for sure, I hope that there is an appropriate place that you can speak out about this individual, as we do all kinda try to look out for each other. I appreciate that this is not the place to do it, but hey - you were just trying to protect others ultimately, and I say thank you for that.
Good luck with the build, I hope that it will be as painless as possible considering the circumstances.
I thought it would be easier to do things right also. That's why I bought all new EVERYTHING. I spent almost $300 on a Mitsubishi OEM overhaul kit so nothing had to be reused. I spent the money to get OEM timing pulleys, tensioner and belt. All of that stuff was stolen and used on his 2.3 stroker build that was going on at the same time and I got all used felpro, goodwrench, and other crap aftermarket brands and nothing returned to me. Dude is dirt bag and a thief.
