fmic installed now no start
champscl
Sep 14, 2009
Back in apex,nc, North Carolina
Ok i installed a fmic kit on my car today and after everything was back on it wont start. I checked all my plugs and wires and fuel. I installed a afpr and a walbro 255 rewired before the fmic and it started fine. Now nothing, It acts like it wants to start and will almost catch but just turns over. What gives anybody got a clue let me know something.
Do a boost leak test at the turbo and verify any plugs you removed by un plugging and plugging back in.
i had a similar problem like this sense u installer a safc or afc iam hoping u had someone who knows how to tune it right tune it for u if u havent tuned it or u dont know how to program it right ## injectors are over spraying fuel inside the engine this is whats making ## engine not to turn on it turns like its going to go on but it dosnt it stays doing the same and the same as long as u try to crank it up, normally if this is ## problem wish it was mine and had same thing done to mine u should smell around ## engine an exesive gasoline smell if u smell it then its the safc or afc not programed right and iam sure sense u put an afc u also added bigger injectors am i right or wrong?:confused:
Thanks for the replys. I did all that and it didnt work Im going to start over from the begining and see what happens. Its probably something simple.
Sorry Im running stock injectors and stock ecu. Im going to pte 880's and aem as soon as I work out these bugs.
