Fmic HeLP
Does the FMIC has mounts on it? Did it come with any hardware? Did it come with pipes made for your car?
I got a injen FMIC. How do i mount it? and whats the best route to run it?Where do i run the pipes from the intercooler?:hellyeah::rocks:
Can you please post pictures of the kit?
"How do I mount it?" Literally any way you can that is secure. It most likely will involve trimming/cutting of your bumper, and possibly relocating or moving lines.
"whats the best route to run it?" Pictures will help here to see the type of kit you have. You don't really have much flexibility as to how to run it, it is dependent on how it is set-up( long-route vs short route)
"Where do i run the pipes from the intercooler?" One end of the intercooler pipe will connect to the UICP, or throttle body depending on the kit, and the other end will connect to the turbo outlet.
