fmic diy piping q's? with pics
spidy3
192
4
Jan 20, 2005
upstate, New York
I purchased a jrc fmic and some piping from jcwhitney. Routing the piping on the pass. side was pretty easy, I just used the stock location. As for piping on the drivers side im not sure which way I should run it.....
Pic 1 I circled hole where power steering lines and A/C line goes through frame and I drew a pipe in with the other routing that I could go.
Pic 2 shows the hole better (would have to try and cut bigger to fit piping in)
Now, for the "yellow" routing the piping would have the airflow taking a 90* turn or slightly more, and the "red" routing the piping will be exposed a little underneith car. It would be under frame next to tow hook and come into engine bay between fan and alternator.
Any and all suggestions are welcome. :cool:
:talon: Dom
I just drilled a 3" hole behind the tow hook hole.
I just placed the 180 in the position to come out and back in marked it, and drilled it.
I will see if I can find some pics and post the link to them.
http://joe.kowalski.home.mchsi.com
Sorry just looked through them and the drivers side is not pic'd...
But I just laid it out like I said above.
