Flywheel step for ACT 2600
peypey's ride
237
Jul 25, 2007
Lilly Lake, Illinois
I have an ACT 2600 w/street disc and a Clutch Masters Lightweight Aluminum Flywheel with a changeable friction plate. With my first set up I ran a CM clutch with the flywheel. Since then I changed and went with the ACT 2600 clutch. Now for some reason after I did the break in, a sound was coming from the trans area. It would get louder the faster I went, until I pushed in the clutch. Well, eventually it burned out my TorBearing in the trans. Now I have a new trans and finished rebuilding my motor once again. I am using the same clutch and flywheel with a new ACT street disc. The old one, the 6 springs in the inner of the disc are very loose! Thats why I got a new disc. Now that I have it all put back together i took the car out for a test drive, all was good and fast. But the noise that I heard long ago is back, just not as bad as before. I now its not the trans, cause its been rebuilt. I now its not U-joints or transfer case. My real question is this, could this noise be because I need to restep the flywheel to match the ACT clutch? I know that I will need to drop the trans again. Just looking for any input on this. Does anyone else have this flywheel? Or set up?
Well I measured the steps myself and they were sitting at .641. So, I am haveing them taken down alittle bit to .612. I will throw it all back together as soon as I get it back, and we'll see if that solves my problem.
