Calan
DSM Wiseman
- 7,250
- 400
- Jan 16, 2007
OKC,
Oklahoma
Two questions:
1. What is the hole in the crank and flywheel (that is not a bolt hole) for? It looks like a spring pin goes there for alignment, but mine didn't have it when I pulled it. (And the flywheel has rust in that hole, so I know I didn't just overlook it). If it is there, it got buried back into the crank somewhere in the past.
2. If this is not for a pin, should there be a tiny bit of rotational play with all 6 bolts in? I have a new flywheel and new bolts... with all six in and finger snug, the flywheel stays centered and flush, but will rotate around the crank just enough to feel it; maybe a few thousandths.
The manual doesn't show any alignment pin that I can see, so I'm a bit perplexed...
Thanks
Thanks
