Fluidamper Crank Pulley
Spoolin98
1,646
23
Feb 1, 2004
Easton, Pennsylvania
Ok so I did some research on here and couldnt find what Im looking for.
I swear I saw somewhere on tuners a couple months ago that the Fluidamper crank pulley has 2 sets of timing marks on it?
Is this true? I think I read one was for DSM's and the other for EVO's.
If so, is the only way of knowing if I set my base timing to the right mark by finding an OEM crank pulley and matching up the marks?
Or can someone send me a picture or link showing me which is the correct line?
If you have a timing light with an adjustment on it, you can adjust it to 5*. Then point it at the cam gears and the inner timing marks will line up when your timing is set correctly.
