Flash's Summer Build Thread
Here are some updated pictures of today. Not much progress as I have been extremely busy now that I'm back at school. I mounted the Stack water temp sensor and ran the wire. I then discovered my dumbass messed up running my fuel pressure wire.
The wires are all labeled on the Stack wiring loom.
Fuel Pressure= A
Fuel Level= F
I ran the Fuel Level wire to the fuel pressure sensor. I spent 20 minutes looking for the fuel level wire when I was ready to run it to my tank, I was completely stumped and thought Stack sent me the wrong wire loom. Because Stack conveniently labels all the wires, I quickly found my mistake. I gave up after I found my mistake, I wasn't in the mood to re-run a wire when I had Finance homework to do (real hoot too!).
Still need to finish wiring.
Spotless.
Heated the neck up, pulled the steel fitting out, rethreaded for 12x1.5 and stuck a -6 cap on it. I didn't have access to NPT taps. Much better than a ghetto black rubber cap that's hose clamped on. I must point out the surface of the water neck. I massaged the metal a bit and took out any casting marks.
Here is what I started with.
Looks nice. Awesome job.
James :laser::talon:
Haven't updated for a while, because I barely get 2 hours a week to touch my car. I finished mounting the Stack. I pushed hard last night and early this morning to get my car started. I tried starting my car today and found a coolant leak on the fitting I put on the block. I used sealant, a crush washer and even torqued it down, but it just barely leaks. So the turbo must come off again so I can fix it.
I'm happy with the mount I made, tried to make it as OEM looking as possible.
Let me know what you think. I'm 99% sure I'm going to scrap that mount on my steering column where my turbo timer is mounted. I need a place to mount the sequential shift lights when they come.
Sweet. What model steering wheel is that? and how hard was it to install the adapter to the stock piece?
dude...that looks cool...any other pics of the dash?
GREAT WORK!!!
I don't, I will try later.
Sparco 345. It's in their competition line. I figured I would give it a try and if I don't like it try another. It takes 5 minutes to swap out. Installing the adapter was easy.
What happened to the Lap 5 wheel? Just got tired of it? Maybe I'll take it off your hands for you? :sneaky:
Sexiness.
I gave it to a friend. He was building up his car and was missing a steering wheel.
It better be, for the price paid.:shhh:
It has been well worth the money. I think it's better than having a million little gauges scattered around the interior.
Suede wheels looks great Flash :thumb:
Thanks!
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
