flashable ecu to 97 gst????
newtodsm97gst
289
Oct 23, 2011
Lewisville, Texas
I'm still waiting for the tactrix cable, anyway since I'm installing my wideband today I'm going to swap my ecu to 98/99 flashable ecu, now the question is do I just plug and play and the yellow wire from mtx-l wideband connect to pin 76 for o2 front sensor, again its a 97 so i dont need to swap spark plug wires right?
you will need to swap spark plug wires. i put a flashable in my 97 and it wouldn't start if i didn't change the firing order.
i see, what about the other question I have? any Idea? and whats the swap order? sorry i know i need to search but if you know please tell me thanks
i dont know the stock firing order but you swap the inner plugs to the outer plugs. the two in the right, switch them, do the same with the 2 on the left.
the other question im not sure, i dont have a wideband yet.
I put a flashable ECU in my 97 GST and didn't have to change the firing order of my spark plug wires either.
