DSMmonster123
- 79
- 1
- Oct 15, 2010
South Florida,
Florida
First time doing a timing belt job. everything looks good and tension "looks good" by eye.
Heres my problem. I'm reading that if you can pull and reinstall the grenade pin that the tensioner should be at the bottom of the spec. However when I measure the tensioner gap with a feeler guage and calipers I'm getting .123" and I can't get a .150" dirll bit into the gap.
Should I rely on the specs in the VFAQ .150"-.180"? Or should I go by the grenade pin method? I'd rather have it tighter than too loose. Its going to rain today so I have some time to plan this out before I touch it again.
