first tune
dsmtalontsi95
268
Nov 5, 2007
glenvile, Pennsylvania
I've been working on getting the ltft to zero. I got close, could someone review this just to make sure everything else looks good?
Have you seen this before?
v3combinedft [ECMTuning - wiki]
Unless you're using a 95/96 CAS, you need to check the box in the Misc tab stating "Use non-95/96 style cam angle sensor."
Your AirFlowPerRev looks high. It should be around .28 at idle.
Your coolant temps are pulling timing (2* over 220 and 1* over 206).
Other than that, it looks pretty good for your idle trims. Have you done your rev and cruise trims as well?
So I should just log the combined instead of having each the lo and the mid? I'm pretty new at this.
