first time running car hard and feel vibration
My91TalonTSi
115
Jun 5, 2004
Freehold, New Jersey
I've been slowly restoring my 91 Talon and took it out yesterday for a couple of wide open throttle runs to see how she feels.
The first couple of pulls were great. I had my boost set at 12psi, there was no knock and the car felt pretty good considering it has been sitting off and on for 10 years.
Later in the day I took her out again. The first WOT pull was ok, but the next one wasn't. I got through 1st and 2nd gear fine, but as I got into the upper RPM's of 3rd gear the knock gauge shot up and the car started to shake pretty bad. I'm still trying to rethink the scenario over again to figure out if the car shook first and then the knock gauge pegged or vise versa. Obviously, after I saw the gauge peg, I immediately backed off the throttle, but the car was still shaking. It almost felt like a tire out of balance. The car was shaking and so was the steering wheel, so I nursed her back to my shop and parked it. I never felt the car break up or sputter when it started to knock.
It's going to be a few days before I can dig into the problem, but I would like to hear everyones thoughts. I read a thread about engine/car shaking induced knock, but it seemed no one really had a solid opinion on this.
What do you all think?
After some more searching and reading I came accross an interesting thread about the driveshaft u-joints going bad and causing vibrations. I am going to look into this.
My tires are new and recently mounted and balanced and one of the axles had just been replaced because of a torn boot so I guess I can rule that stuff out.
Impressive Mod List, I don't see it but I'm sure you've done the BSE - If by some chance you have;nt those symptoms are classic & park it until you do...
Are you referring to eliminating the balance shaft? If so, I have not done that yet.
I had my bolts on the driver side axle carrier bearing walk out,felt similar to what you describe,or im thinking you blew a ujoint
I will be definitely checking the u-joints this week and will also check the carrier bearings too.
Thanks for the suggestions guys. I will post back when I repair the problem and let you know what the fix was.
Once in a blue moon it;s a loose Alternator Bolt or something simple - But your lack of BSE REALLY strengthens my well educated guess that it's a Balance Shaft Knocking - Once again I'd park it & tear down the front case, no sense destroying a good Head - Good Luck
