First time porting, tell me what you think
boostsickness
33
Mar 15, 2009
mississauga,
I finished up the porting today. It was my first time porting, and i would just like some feeback and any places you guys think can be ported a bit more
2g 02 housing and e16g
I havent ported the 02 outlet yet. I'm still undecided because i dont have a larger gasket. Thanks, i'll work on that a bit more.
The gaskets are definitely available though, no sense in porting everything and leaving the o2 outlet alone. at least remove the step
Thats true, alright im going to pick up a gasket on my way home from work tomorrow. Do you guys think it'll be enough to eliminate creep? does a 34mm flapper really make a big difference?
If you're porting you shouldn't need the flapper. For most people (unless they have horrible BC) it's an either/or thing, because with the 34mm flapper it gets harder to fight pressure drop at a higher psi, ~20+ psi.
