Just Finished Tell Me What You Think
one_bad_7
65
Oct 5, 2008
lake in the hills, Illinois
Ok so here it goes. This is my second DSM my first was a stock 92 Laser FWD that i had no intentions to modify becuase it was a daily driver. now this one is another story.
I bought the car locally here from a guy who took ok car of the car.
When i bought the car it had a "cracked head" which was really a bad head gasket.
over the last month i stripped the car down and rebuilt it. here are the mods and pics tell me what you guys think.
ENGINE MODS:
.30 BORED ROSS RACING PISTONS
EAGLE RODS
ACL MAIN AND ROD RACING BEARINGS.
COMETICS HEAD GASKET
NEW WATER PUMP
NEW OIL PUMP
ALL NEW FELPRO GASKETS.
NEW RADIATOR HOSES
FUEL AND INDUCITON:
"FRANKENSTEIN TUBRO" .57 TRIM .68 A/R EVO III 16G HOUSING
255 WALBRO HP FUEL PUMP
650CC INJECTORS
APEXI SAFC II CONTROLLER
MANUAL BOOST CONTROLLER
CUSTOM 3 INCH COLD AIR INTAKE
SPEARCO FMIC AND FULL 2.5 INCH PIPING
DNP TURBO MANIFOLD
R&D CATBACK WITH MY OWN MODIFIED APEXI DOWNPIPE TO MAKE IT MATCH UP.
WHAT KIND OF NUMBERS DO YOU THINK THIS CAR WILL MAKE????
I Started it up on thanksgiving for the first time and she sounds awesome.. just have a few more things to do and she hits the road. i did drive it around parking lot and gave it a little gas she definately will pull pretty hard.
Just waiting on my boost controller i tihnk.
let me know guys thanks.
BTW no power steering is rough on this car. all my cars have no power steering and this seems the toughest
that shaved VC is deff. unique :thumb:
looks like it was a fun build. any particular reason you didn't build the head? cams would've helped out on the top end alot
Very true. I want to go with either 225 or 245 on my old rx7 rims, but im still doing my research on what size is better
i am working on recirculating now. i used the Legris air fittings to as you can see on the hard pipe near throttle body.( maybe) just no air hose on there yet.
like i said a few things i need to do still
you need to do something about that kink in the uicp, ( the lon blue piece after the bov) looks kinda rigged
i wanna ask "one bad 7"....you know how the rx7 had 4pot front brake calipers do you think they would if on a talon... because i have a set form my old rx7 and i think it would be a nice brake upgrade???
i have a set of calipers of my third gen i will try. you might need to make a bracket thoug. if i were to go through all that work i would jsut make brackets for the evo brakes.
the parts for kink is on order already. thanks for looking out.
i ran the car on and off for around 1 hour 30min. jsut to check for leaks. i then drove it around the parking lot. i only went to around 3500. but it was pulling hard. i didnt catch the boost.
i wanna brake it in a little more before i beat on it too much
came with car and I kinds like it. I have a shaved black but like this for now. I do need a timing belt cover anyone got one for cheap???
It would be good to get one, you know, so something doesnt fly into your timing belt and ruin that rebuild. MAP and extremepsi have the zaklee cover that is clear, and looks badass. Also I'm surprised you didnt go with slightly larger injectors and dsmlink, much more powerful tuning than SAFC. as far as cams go did you get hks 264's or 272's? I don't remember a 262 model
264s im sorry. i have a AEM EMS..
i wanted it peppy but not killer powerful until next year maybe.. i have another project right now eating up every penny i got
today my little brother was helping me and was tightening down turbo drain bolt nad snapped one. so the turbo came out and DAMN IT. but its ok should be back together and going tomorrow.
so you have an aem ems you aren't running yet? I think this will be a great setup- your mods look carefully chosen and they're all there, how much boost do you plan to run?
