MarkAngelo05
- 201
- 2
- Nov 7, 2006
Pearl City,
Hawaii
Hi there, I went on the dyno today, and I did NOT expect to put down huge numbers, but I did not expect such low horsepower ratings...
Here are my mods...
EVO III GT 18G w/ 15 degree clipped TD05 Turbine wheel(not a type), turbo xs HPBC, ETS FMIC KIT, AFC NEO, FIC 650cc injectors, EVO 9 Fuel Pump, Stainless Steel o2 Housing Recirculated dump, 3 inch down pipe (cat eliminator) to a 3 inch exhaust. Aluminum Race Radiator, Turbo XS Blow off valve, PLX Devices AFR DM-5 Wideband unit, Keydiver's DSMCHIPS Stage 3 chip.
Okay, here's the deal. I tuned for little to NO KNOCK which put me around 11.5:1 on 3 gallons 92 octane gas w/ a bottle of that STP octane booster(which most likely did not help at all.
First pull I laid down 255 HP @ 18psi boost. I turned the boost up to 19psi for the 2nd pull which got 260.85 WHP.
3rd run was 19 psi and I had leaned the air fuel about 2% on the afc from 5k up. Should have left it at +14% from 5k up, but since I didn't get any knock on the second pull, I thought I could lean it out a tad bit.. but that was a bad idea since I started knocking at around 5.5k. I'm not very pleased with the numbers I got, but this is on stock cams, and my intake temps were around 100 @ the MAS. What do you guys think?
It is very weird because with my dsmchips stage 3 chip, my car runs naturally lean for some reason. I have to keep at least +14% on the AFC to not get leaner than 11.5:1 air fuel ratio... Jeff was thinking that I may have a leak in my fuel system, but I'm sure I don't because I installed everything very well and inspected over again. If I had some kind of pressure leak, wouldn't it run INCREDIBLY LEAN during WOT Under boost? Pretty much, without AFC correction, my wideband reads 13:1 to 12.5:1 air fuel ratio.. I have to set it around +16 to + 18% just to get it to hit 11:1 a/f ratio. What could be the problem. I also have bypassed the AFPR solenoid to eliminate that as the problem.
For the 2nd pull, my peak timing was 15 degrees at 6.4k rpms, dropped back to 14 degrees by 6.8k rpms.
The 3rd pull timing curve seems very awkward, it's not smooth at all.
I logged during the 2nd and 3rd pulls, so here are the logs..
Any information will be greatly appreciated. Thanks in advance!
Mark
Here are my mods...
) First pull I laid down 255 HP @ 18psi boost. I turned the boost up to 19psi for the 2nd pull which got 260.85 WHP.
Mark
which was not too cool... that's why on my last run, my o2 voltage was still around the high 90's and in the 1.0v area, and slight knock came in and caused me to get only 237whp...
keydiver, dsmchips.com is awesome!
