Korndogg
- 471
- 0
- Jun 21, 2003
randolph,
Vermont
hey guys
i went to the dyno for the first time yesterday and i must say i'm a bit disapointed.. i have lots of data though and several questions that i was hoping you guys would be willing to help with.
i have attached my final dyno graph. 256HP to the front wheels with my mods seemed low to me..
EVO3 16G @ 20PSI
580CC injectors
190LPH fuel pump
FMIC
full 2.5" turbo back.. o2 eliminator, test pipe, catback.
ngk bpr7es plugs.. 6 weeks old or so
Compression is still good..
172 - 162 - 170 - 165
this was a 4th gear pull.. 2000-7000rpm
Enviromental conditions:
81degreesF
29.87 in Hg
30% humidity
now my questions...
a) they wanted to adjust my AFR so that it was at about 12:1.. i asked for more like 11.5:1 because i was under the impression that 12 was getting fairly agressive and my motor lasting is more important to me..
b)why does my fuel ratio dip just after 4.5krpm? they played with the AFC but were only able to get the dip to move up and down...
c) why am i still so lean under 3000rpm? is this normal AFR off boost?
d) and most importantly... i was logging during the runs and this is my log for the last run... this seems to show me an aweful lot of knocking.. what's the deal? which is right? timing being pulled or the wideband O2?
RPM Timing
2028 28.5
2068 22
2120 17
2192 16
2276 15.5
2360 15.5
2456 14.5
2544 13.5
2644 12.5
2748 11
2856 9
3288 5
3472 4
3652 7.5
3844 6.5
4028 6.5
4208 7.5
4376 7
4592 7.5
4756 8
4908 10
5096 9
5260 10
5420 9
5604 10
5772 11
5932 11
6056 13.5
6220 11
6356 11
6496 11.5
6608 11.5
6748 12.5
6844 10
6968 10
7084 10.5
the guys at the shop thought my AFC might have been advancing my timing too far.. they suggested i find a way to adjust my base timing. anybody agree/disagree? and how would i adjust my timing considering i have one of the few early 2G blocks with the damn CAS burried in the block, not up on the valve cover.. i don't think that the MDS DIS's will play with timing will they?
thanks for all the help guys.. much appreciated
any suggestions would be very well taken.. my goal was 300-320whp
Thanks!
EVO3 16G @ 20PSI
580CC injectors
190LPH fuel pump
FMIC
81degreesF
29.87 in Hg
30% humidity
now my questions...
RPM Timing
2028 28.5
2068 22
2120 17
2192 16
2276 15.5
2360 15.5
2456 14.5
2544 13.5
2644 12.5
2748 11
2856 9
3288 5
3472 4
3652 7.5
3844 6.5
4028 6.5
4208 7.5
4376 7
4592 7.5
4756 8
4908 10
5096 9
5260 10
5420 9
5604 10
5772 11
5932 11
6056 13.5
6220 11
6356 11
6496 11.5
6608 11.5
6748 12.5
6844 10
6968 10
7084 10.5
Thanks!
