First pocket log
dont need 8
349
Oct 8, 2002
Frisco, Texas
ok, here is my first log just messing around.
What parameters should I focus on and what gear should I pull, 3rd or all? Here is a small 2nd to 3rd to 4th gear pull. I was afraid of police hiding so I took it easy.
I hope you can read it, it shows all parameters.
One thing to note is that if your getting say 15 samples/second with your logoer and you log 15 things at once, your getting one sample per second of each. If you long log 5 things you will get 3 per second of each. So when your logging to tune your car, just log your RPM, Timing, Front O2 that way you will get more reading per second. Your logs shows about 3-4 data points that are useful the rest is totally garbage and not really needed.
