firing order with COP
woooop
411
May 25, 2005
lakewood, Washington
I have a 97 that i just put a 6 bolt in and i plan on putting a 95 Eprom in. Do i need to swap the coils on the cop around ? And if so wich ones ?
So whats the order of a 97 on the valve cover pas. side to driver side and what is it on a 95? I can just swap coils right? Im so confused aaarrrr
There's a huge thread on it somewhere. Search for it. Give me 2 minutes to hit up MSpaint for ya.
Here's a picture. When you are using a 1G CAS with a 95 EPROM, you will have to switch the wires around like so. If you are planning on running DSMLink with that eprom, choose INVERT CAS in the MISC options.
So i whould just swap my coils around to the firing order of the second pic or do i have to rewire the whole thing?This cop has me all messed up. If i dont figure this out i might jus use reg coils spolin thanks for your help you the man
Is this right the coils on the cop go 4123 on the 97 so i have to switch the coils to go 3214 on my cop plate for my 95 :thumb:
getting spark tech COP have dsmlink, so im all good to hook everything up like normal and invert CAS signal huh? that sounds much easier then having plug wires going different ways at the moment. thanks for this info i dont know why i didn't do this before hahaha
old thread, but i dont care heh. google tends to bring up good old info :cool:
