Firing Order Help
Dsm96GSX
May 16, 2014
Mooresville, North Carolina
Hello everybody thank you for viewing my post.
I had recently done a spark plug change and made the rookie mistake of disconnecting all of the plug wires without labling them. I have attempted to put them back in the right order but with little success. The car does start up and run but it idles very rough and low. A little background to my car is that it is a 1996 eclipse gsx with a 6 bolt swap if that makes a difference. Any help would be very appreciated.
Here is a link to the current firing order I have it in:
https://docs.google.com/document/d/1kGmKkeXsW9MuFMqgaA3iUdH0eCV8OOSBS7QF26rRWwk/edit?usp=sharing
You've done a 6-bolt swap on a 95-96 so, assuming you have a 1g CAS, the firing order is exactly backwards then what the coil pack bracket lists 4 - 1 - 2 - 3.
That being said, looking at the picture you've got the firing order exactly inverse which is 3 - 2 - 1 - 4 so it's not your firing order causing your issue.
With that, next time search for the answer first.
http://www.dsmtuners.com/threads/6-...nd-2g-coil-pack-cant-get-firing-order.298222/
