Finally in the shop (long)
Toshiro
372
Dec 21, 2003
Sacramento, California
Well, the other day I did something I haven't ever really done before- I dropped my car off at the shop and said "I don't know what's wrong with it." Kinda sucks, but I had it coming. I went through the Evo3 16g install from hell a couple weeks ago (1 helicoil, 1 ez-out, 3 taps, 1 die, 2 coolant/oil changes, 1 custom weld job, 1 custom oil feed line, 1 battery terminal, several gaskets, etc etc etc :notgood: ) and the car still had some sort of boost leak (late boost). I figured it was leaking out of the newly installed 550 cc injectors, because I got them from a private party with some suspicious-looking gaskets that didn't seem to fit quite right. I replaced all of the larger injector o-rings, leaving the smaller ones on top. It spooled earlier, but still way too late. I was way tired of working on it, so I just said forget it and decided to drive it for a while with no boost. After a couple weeks I was just cruising down the freeway and saw some grey smoke in the mirror. Exited and popped the hood, and I was greeted by more smoke coming from the rear of the engine, near the injectors. I didn't really feel like sticking my head in for an investigation while it was smoking, because I like my face. After a little while I nursed it to a shop and left it overnight. When I went back to tell my long story to the tech, the only new thing that I really noticed under the hood was a slightly larger puddle of oil in the spark plug well. He said they'd call me after they did their 1.5 hour diagnostic on it, but I haven't talked to them yet. I guess this is all just a big vent / confession, but I'll definitely keep everyone posted once I hear from the shop.
[cliff's notes]
Horrible 16g install, car had boost leak. Driven w/ leak for a couple weeks, then random grey smoke. Dropped off @ shop, haven't heard from them yet.
:dsm:
Well, I went to go check on the car today, and was given the good news and the bad news. The good news is the boost leak was just a loose clamp where the licp goes into the intercooler combined with a broken vaccuum line going to the wastegate. The bad news is the oil return tube from the turbo is leaking oil, causing the smoke and oil accumulation. They said it'd be an extra hour of labor to fix it, so I gave them the go-ahead.
On a lighter note, he said it took the tech an hour to get my car on the rack because it's so low. LOL!
:tease: You took your car to a shop for a simple boost leak test? :mad:
ROFL All they needed was 4 2x4 blocks.
I took my car to the shop because I haven't had any time to work on it in two weeks and I wasn't going to for another week because of work. After spending countless hours installing the new turbo and having every possible thing go wrong I was a bit tired of spending my entire life underneath my car.
