RED_AWD_BLUR
- 57
- 0
- Jan 16, 2003
Columbus,
Ohio
Hey, 1 lb ~ 2.2Kg so 4.5 * 2.2 = 9.9lbs and how would a Jun steel FW be lighter than a 6061 aluminum fidanza?
Originally posted by GreenGSX
The solution is a stepped dowel pin that uses the pressure plate assembly to hold the pins in while still maintaining the centering function of the dowels themselves......did that make sense???
Tim
Originally posted by Rick@AP
Slightly off topic but, why are you guys drag racing with a lighter flywheel? You really want a heavier flywheel not the other way around.
Back to the topic....
Originally posted by GRNDSM
I can attest that Jun makes a VERY light FW. I believe that it is around 9lbs or roughly the same weight as Fidanza.
However, Jun was not expecting to see their FW as beat up as they got abused in AWD DSMs during drag racing. They are fine for road racing or AutoX, but I would not one for drag racing.
Leon
RR
) He's exploded a few stockers as well.Originally posted by FastRthenU
I hope you are joking. But if you are not, why the hell would you think that![]()
Originally posted by JayHass
FYI Pruven only recommends JUN flywheels for big hp drag applications due to this very problem.
Dan has been through over 29 combinations in his 527awhp street car before running what he runs. (well before he sold the car anyway.) He's exploded a few stockers as well.
.Originally posted by GRNDSM
OK then, call up JUN and ask them about what THEY think about using their FWs for drag racing... They do not like it.
Leon
RR
...Leon I'm not arguing with you, I'm simply saying that the JUN is the only unit to hold up so far with no problems regardless of what it's "original" design was for.
