1G Fic fuel rail boost leak
SasaniFab
2,432
788
Dec 1, 2013
Mexico, Connecticut
So im in the middle of making aluminum charge pipes. I did a boost leak test to check the integrity of my welds. I have a massive boost leak at the injector seal. The injector seems to sit loose inside the rail. The injectors are the high z 1650s,i shouldnt be able to slide them up and fown no? I didnt have an issue with the oem rail. Am i missing something?
Mine don't move at all you. have you checked the integrity of the seals? Sometimes they can be installed crooked and you don't notice until gas or air comes spraying out.
Yah ive got to double check....didnt have a chance last night as i was rushing to get my valve cover welded.
  • Wanted 6 bolt NT water pipe
    • chrisman287
